It is currently Mon Aug 18, 2025 4:11 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jun 26, 2014 1:57 pm
First name: Stuart
Last Name: Gort
If anyone would like a free .xls fret placement calculator I created just e-mail stuartgortsr@gmail.com and I'll send it to you.
You simply input the scale and it outputs the fret placements through 24 frets....both in stretch compensated positions and uncompensated positions. I believe the compensated position would be particularly useful for acoustic guitars.
StuMusic
PostPosted: Fri Jun 27, 2014 8:36 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
For those of you who relied on the "old" Stewmac fret placement calculator, it seems that the new version has been updated with the former functionality, including saddle compensation placement.
I ran a comparison with my calculator (linked a few messages earlier in this thread) and confirmed that both continue to give the same compensation results for acoustic guitars.
BTW: one OLF member has contacted me who's experienced problems opening my calculator in Excel 2003/OS-X and in Numbers for iPad. I can't reproduce the problem, so wondering if anyone else has run into similar problems?
PostPosted: Fri Jun 27, 2014 9:55 am
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
It seems to be working exactly as before
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Fri Jun 27, 2014 10:29 am
[clap]
PostPosted: Tue Jul 01, 2014 2:08 pm
I'm glad it is back. I few months ago I was curious as to how they were calculating the saddle compensation. I ran a bunch of numbers through it and I think I stumbled on to the formula that they use. What they seem to have done is set the main compensation based on a 25.0 inch scale length and then added 1/8" to that. That is for the center of the saddle. They then angled the saddle 3 degrees. I think that it is 3 degrees. I can't find my notes to double check.
They then scaled the compensation based on the scale length. That gives us the following formulas:
Steel String Acoustic
Low E compensation: Scale Length * 1.0084
High E compensation: Scale Length * 1.0035
Classical
Center of saddle compensation: Scale Length * .1003
As other posters have said, this formula gives a pretty general starting point but the number may change depending on string gauge and action so YMMV.
